[gdal-dev] WAsP map output for ogr
Vincent Mora vincent.mora at oslandia.com
Tue Feb 25 04:21:43 PST 2014
I'd like to develop a ogr driver to create .map files used by WAsP
<http://en.wikipedia.org/wiki/WAsP>
The .map files contains height contours and roughness zones, the former
are linestrings with an height attribute, the later are linestrings that
separate two adjacent polygons with a roughness parameter on the righ
and left sides.
An algorithm to create roughness zones from polygons with a roughness
attribute would be useful: extract the polygon boundaries and output
linestrings with attributes on the left and right sides.
What driver would you recommend as a starting point to get the
interface, the coding style and the error handling right ?
Is the algorithm to create roughness zones from polygons (i.e. extract
polygon boundaries and add left/right attributes) something that should
be integrated in the driver, somewhere else or not at all in gdal ?
Thanks,
V.
