[gdal-dev] GDAL C# bindings - using rasterlite and spatialite in the same database
Marcel Gangwisch gangwism at informatik.uni-freiburg.de
Thu Feb 27 12:39:52 PST 2014
Dear Even,
thank you for your answer! I think I know the real problem now.
Respectively Sandro (I think a developer of rasterlite) gave me the
correct hint.
(https://groups.google.com/forum/?hl=de#!topic/spatialite-users/g8b3va_zteg
<https://groups.google.com/forum/?hl=de#%21topic/spatialite-users/g8b3va_zteg>)
For the generation of the spatialite database I used spatialite 4.0...
But the precompiled gdal version (http://vbkto.dyndns.org:1280/sdk/) I
used, uses spatialite 3.0...
I checked that, with the spatialite-gui.
So like Sandro wrote:
/"in this case a "new style" DB-file will be created in the first step; //
//but librasterlite hasn't the capability to access "new style" DB-files, //
//so any further attempt to import some raster data will then fail. /"
The Question is now, what to do...
Obviously I want to use the newest spatialite version.
Therefore I thinking about building gdal against spatialite 4.
On the other side, Sandro wrote, that rasterlite 2 will be coming soon.
So maybe I just stay on spatialite version 3. And use later version 4.
Best regards,
Marcel
Am 27.02.2014 20:23, schrieb Even Rouault:
> Le mardi 25 février 2014 18:12:55, Marcel Gangwisch a écrit :
>> Hi *,
>> I use the following command:
>> rasterliteDriver.CreateCopy("RASTERLITE:GeoDatabase.db,TABLE=raster_test",
>> source, 1, options, null, null);
>> to read every gdal raster in my rasterlite database. After reading I'm
>> also able to read another raster of vector file into the sqlite
>> database. Everything works fine.
>> My Problem is now if I do this the other way around:
>> Then I first read a vector file into a spatialite database, and after
>> that I want to read a raster file into the same database I get the
>> following exception:
>> "does not exist in the file system, and is not recognised as a supported
>> dataset name"
>> Does anybody know what I'm doing wrong?
> Marcel,
> You should provide something more precise to reproduce. I've tested
> successfully the equivalent operations of what I've understood of your above
> description with the following command lines :
> ogr2ogr -f sqlite poly.sqlite poly.shp -dsco spatialite=yes
> gdal_translate -of rasterlite byte.tif RASTERLITE:poly.sqlite,TABLE=byte
> and then both ogrinfo and gdalinfo show the vector and raster layers.
> Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140227/6ffea5ae/attachment.html>
