[gdal-dev] gdal get geolocation array in HDF5 dataset
Heather QC heather.cronk at colostate.edu
Fri Feb 28 09:01:41 PST 2014
Laura,
Did you ever sort this out? I am having the same problem with both HDF4 and
HDF5. I can open the geolocation datasets if I know the name, but I would
like to be able to list them to extract the name and automate.
Thanks!
Heather
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-get-geolocation-array-in-HDF5-dataset-tp5086505p5106680.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
