[gdal-dev] Fwd: Can not open bigtiff file using gdal1.10 API saved by photoshop cs6
ridge wang ridgewang at gmail.com
Fri Feb 28 09:07:53 PST 2014
---------- Forwarded message ----------
Date: Sat, Mar 1, 2014 at 1:06 AM
Subject: Re: [gdal-dev] Can not open bigtiff file using gdal1.10 API saved
by photoshop cs6
To: Even Rouault <even.rouault at mines-paris.org>
I working on Windows 7 64bit OS, Build the gdal 1.10 32bit version with
microsoft visual studio 2005 32bit. and using the internal libtiff version
of gdal.
On Fri, Feb 28, 2014 at 9:26 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Selon ridgewang <ridgewang at gmail.com>:
> > Ps, sometimes it creates bigtiff file without any error reports by gdal
> 1.10
> > api, but can not open the tiff file by gdal api and reports zero
> stripsize.
> > anyway, the photoshop cs6 can open the tiff file correctly. for tips that
> > the file is created and save in a usb mobile harddisk. I wonder why the
> > photoshop so robust can open the tifffile with a zero stripsize?l
> Could you add in the ticket details about your GDAL build : OS, 32/64 bit
> build,
> use of internal libtiff or external libtiff (in the later case, which
> version).
> > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-Can-not-open-bigtiff-file-using-gdal1-10-API-saved-by-photoshop-cs6-tp5105979p5106514.html
> > Sent from the GDAL - Dev mailing list archive at Nabble.com.
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140301/b4cb4d33/attachment.html>
