[gdal-dev] Fwd: Can not open bigtiff file using gdal1.10 API saved by photoshop cs6
Even Rouault even.rouault at mines-paris.org
Fri Feb 28 14:32:02 PST 2014
OK, problem reproduced and fixed. It was specific to 32 bit builds, and with
TIFF files made of a single strip of more than 2 GB. (note that your file is a
classical "big" TIFF, but not a "BigTIFF")
Le vendredi 28 février 2014 18:07:53, ridge wang a écrit :
> ---------- Forwarded message ----------
> From: ridge wang <ridgewang at gmail.com>
> Date: Sat, Mar 1, 2014 at 1:06 AM
> Subject: Re: [gdal-dev] Can not open bigtiff file using gdal1.10 API saved
> by photoshop cs6
> To: Even Rouault <even.rouault at mines-paris.org>
> I working on Windows 7 64bit OS, Build the gdal 1.10 32bit version with
> microsoft visual studio 2005 32bit. and using the internal libtiff version
> of gdal.
> On Fri, Feb 28, 2014 at 9:26 PM, Even Rouault
> <even.rouault at mines-paris.org>wrote:
> > Selon ridgewang <ridgewang at gmail.com>:
> > > Ps, sometimes it creates bigtiff file without any error reports by gdal
> > 1.10
> > > api, but can not open the tiff file by gdal api and reports zero
> > stripsize.
> > > anyway, the photoshop cs6 can open the tiff file correctly. for tips
> > > that the file is created and save in a usb mobile harddisk. I wonder
> > > why the photoshop so robust can open the tifffile with a zero
> > > stripsize?l
> > Could you add in the ticket details about your GDAL build : OS, 32/64 bit
> > build,
> > use of internal libtiff or external libtiff (in the later case, which
> > version).
> > > View this message in context:
> > http://osgeo-org.1560.x6.nabble.com/gdal-dev-Can-not-open-bigtiff-file-us
> > ing-gdal1-10-API-saved-by-photoshop-cs6-tp5105979p5106514.html
> > > Sent from the GDAL - Dev mailing list archive at Nabble.com.
> > > _______________________________________________
> > > gdal-dev mailing list
> > > gdal-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
Geospatial professional services
http://even.rouault.free.fr/services.html
