[gdal-dev] Fwd: Can not open bigtiff file using gdal1.10 API saved by photoshop cs6
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Fri Feb 28 23:57:59 PST 2014
ridgewang <ridgewang <at> gmail.com> writes:
> 3. The tiff file I created is in tiled formation with block size 256x256.
So what does the single stripsize means?
This means that something has gone wrong. Your sample was not tiled but the
blocks were made of single scanlines from left to right. Check with gdalinfo
Band 1 Block=37531x1 Type=Byte, ColorInterp=Red
Band 2 Block=37531x1 Type=Byte, ColorInterp=Green
Band 3 Block=37531x1 Type=Byte, ColorInterp=Blue
-Jukka Rahkonen-
