[gdal-dev] SetAttributeFilter and OSM
agerrius arno at agerrius.nl
Sat Jan 4 08:12:36 PST 2014
Hello,
I'm using the GDAL/OGR libraries in a C# application and I have some trouble
with the SetAttributeFilter function on an OGR layer.
The filtering works fine when I load a SHP file, but when I load an OSM file
it doesn't work. I still get all the features on the layer. Is this a known
limitation of the OSM reader or did I make a mistake somehow?
Thanks,
Arno
View this message in context: http://osgeo-org.1560.x6.nabble.com/SetAttributeFilter-and-OSM-tp5096352.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
