[gdal-dev] Convert GeoPDF with gdal_translate
Pekka Sarkola pekka.sarkola at gispo.fi
Tue Jan 7 21:41:49 PST 2014
Thanks Even!
And also Jukka and Ari. Jukka: Is there still Windows machines in Finland? Interesting, Land of Linux ;-) Well, even I have few.
Ok, I try GDAL versions with 3rd party librariries
I agree with Ari: gdalinfo should some how show that it has only write option. This maybe bigger change. Should I add this to feature request page?
Rgs,
Pekka
---   Pekka Sarkola  -  pekka.sarkola at gispo.fi  -  www.paikkatieto.com   ---
-----Alkuperäinen viesti-----
Lähettäjä: Even Rouault [mailto:even.rouault at mines-paris.org]
Lähetetty: 7. tammikuuta 2014 23:02
Vastaanottaja: gdal-dev at lists.osgeo.org; Pekka.Sarkola at gispo.fi
Aihe: Re: [gdal-dev] Convert GeoPDF with gdal_translate
Le mardi 07 janvier 2014 20:51:32, Pekka Sarkola a écrit :
> Hi!
> Maybe newbie problem. I download GeoPDF file from
> http://lib.utexas.edu/maps/topo/nicaragua/ and try to get information
> with gdalinfo and translate with gdal_translate.
> Both command response: "ERROR 4: `argelia-nicaragua-50k-3154iii-1981.pdf'
> not recognised as a supported file format."
> GDAL version 1.10.1, both on Windows and Ubuntu. gdalinfo -formats
> recognize PDF-format as supported.
> Is this on my installation or somewhere in gdal?
Not exactly your installation, but the build you've picked up. I've verified this is a valid geospatial PDF file recognized by the GDAL PDF driver.
I assume your GDAL build has only write support for geospatial PDF (which doesn't require any third-party library), but not read support that requires linking to a third-party library, like Poppler or Podofo. Unfortunately gdalinfo --formats can only report read/write support even when it's write- only.
> Rgs,
> Pekka
> Pekka Sarkola
> Gispo Oy
>  <mailto:pekka.sarkola at gispo.fi> pekka.sarkola at gispo.fi   - GSM +358 40 725
> 2042
>  <http://www.gispo.fi> www.gispo.fi -  <http://www.paikkatieto.com>
> www.paikkatieto.com
Geospatial professional services
http://even.rouault.free.fr/services.html
