[gdal-dev] Standard Dev. Environment?
Thu Jan 9 20:33:26 PST 2014
Jay,
Are you needing Jasper?  Normally a default build ("./configure") should
work pretty well on a precise system. I'm guessing you have enabled jasper
because it is key to what you want to do?  If not --without-jasper should
be straight forward.
Best regards,
Frank
On Thu, Jan 9, 2014 at 8:00 PM, Jay L. <jlaura at asu.edu> wrote:
> List,
> I wonder if a standard dev. environment exists?  I am working to extend a
> driver and am having trouble getting an environment working that will
> compile.  Current setup is a VagrantVM, Ubuntu 12.04 32-bit with source
> downloaded from SVN.  Attempting to build with minimized drivers<http://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithMinimizedDrivers>as per the build documentation and am having build errors due to
> dec_jpeg2000 (jasper I believe).
> Q: Are devs using a standard environment (or a different flavor of *nix?)?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140109/7d1e26ed/attachment.html>
