[gdal-dev] Standard Dev. Environment?
Alan Boudreault aboudreault at mapgears.com
Fri Jan 10 11:49:32 PST 2014
Yeah, np. My repo only aims for mapserver development. Geobox installs a
lot more stuff, which is not really needed for our stuff.
Alan
On 14-01-10 02:44 PM, Jay L. wrote:
> Have you also seen the geobox environment?
> https://github.com/zhm/geobox
> The install fails as the links to postgres configs are outdated (GiST
> URL changes)  Alan, if you have no issue, I might fork geobox and swap
> in your PostGreSQL lines to get geobox back up and running.  I think
> it is easier to share with beginning users that the OSGEO live CD.
> On Fri, Jan 10, 2014 at 11:41 AM, Alan Boudreault
> <aboudreault at mapgears.com <mailto:aboudreault at mapgears.com>> wrote:
>     The github: https://github.com/aboudreault/mapserver_dev-cookbook
>     Note that I started to upgrade the environment to be compatible
>     with the latest vagrant. I will also update the README file in the
>     repo since the procedure will be easier (since a few things I was
>     using have been directly integrated as vagrant plugin).
>     I plan to finish this during the next week.
>     Alan
>     On 14-01-10 01:36 PM, Daniel Morissette wrote:
>>     On 14-01-10 1:23 PM, Jay L. wrote:
>>>     Success.  Ivan, I used your ./configure flags - stock was also not
>>>     working on this VM.
>>>     I wonder if the dev. community is large enough to warrant storing a
>>>     lightweight Vagrant box image somewhere.
>>     Talking of Vagrant, FYI about a year ago Alan Boudreault wrote a
>>     set of Vagrant and Chef recipes to automate the setup of a
>>     MapServer dev environment (which includes GDAL as a dependency).
>>     The recipes are a bit old already, but it may be a good starting
>>     point for automating the setup of a GDAL dev environment.
>>     If you're interested, see:
>>     http://www.alanb.ca/blog/2013/03/09/setup-a-mapserver-development-environment-with-vagrant-and-chef/
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140110/c0638b5e/attachment.html>
