[gdal-dev] How remove the piramids from TIFF non-georef
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Wed Jan 15 03:36:59 PST 2014
Hi Andrea,
you may consider using
"gdal_translate -b 1 -b 2 -b 3 inputTiff outputTiff"
I assume you are referring to overviews, right?
In that case, gdal_translate won't copy overviews so you are lucky :)
You may also consider adding tiling with "-co TILED=YES" to the previous
command:
"gdal_translate -b 1 -b 2 -b 3 -co TILED=YES inputTiff outputTiff"
Default tiling is 256x256; you may specify different one with -co
BLOCKXSIZE=nnn -co BLOCKYSIZE=mmm
Hope this helps.
Cheers,
Daniele
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
On Wed, Jan 15, 2014 at 12:01 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> I have a lot of huge tiff not-gereferenced raster.
> These tiff are all with 4 bands (RGBA) and 10 pyramids inside.
> I need to remove the piramids and retrieve a new tiff version without the
> piramids and with only 3 bands (RGB).
> Usually this work is do using imagemagick or vips, but I like to try to
> use the gdal-translate to do this.
> But Im not sure , because the tiff are not georef and also I'm not sure if
> gdal is capable to read a 4 pyramid tiff and generate a 3 not-piramid tiff.
> Thx for every hints.
> Andrea Peri
> qwerty àèìòù
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140115/ee7b248f/attachment-0001.html>
