[gdal-dev] gdalinfo coordinates problem?
Reynolds, Scott scott at agi.com
Fri Jan 17 12:28:35 PST 2014
I've downloaded several DEMs (e.g 27002570PAS_dem.zip) from ftp://pamap.pasda.psu.edu/pamap_lidar/cycle1/DEM/South/2008/20000000/.  Gdalinfo is reporting the corner coordinates to be in the vicinity of  91 degrees 31 minutes west longitude which should be more like 75 degrees 36 minutes west longitude.  Can someone explain what is happening here?
Thanks,
Scott
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140117/389682f8/attachment.html>
