[gdal-dev] Problem calling gdalwarp from within python script
Even Rouault even.rouault at mines-paris.org
Mon Jan 20 00:57:24 PST 2014
Selon Simon Richard Proud <srp at geo.ku.dk>:
> Hi,
> Unfortunately that produces a file not found error with filename "65535". If
> I remove both arguments "-srcnodata" and "65535" then I go back to getting
> the usage guidelines.
You need to separate also the numerical values after -te and -tr
['gdalwarp','-q','-multi','-r', 'cubicspline','-t_srs', '+proj=geos +lon_0=0.0
+h=35785831', '-te', '-5568748.2758', '-5568748.4774', '5568748.2758',
'5568748.2758','-tr', '3000.40316582', '3000.40316582', '-srcnodata',
'65535','TEST.tiff', 'TEST2.tiff']
> /Simon
> ________________________________________
> Fra: Kurt Schwehr [schwehr at gmail.com]
> Sendt: 19. januar 2014 19:00
> Til: Simon Richard Proud
> Cc: gdal-dev at lists.osgeo.org dev
> Emne: Re: [gdal-dev] Problem calling gdalwarp from within python script
> have not tested this, but I would guess something like this...
> +lon_0=0.0 +h=35785831', '-te', '-5568748.2758 -5568748.4774 5568748.2758
> 5568748.2758','-tr', '3000.40316582 3000.40316582', '-srcnodata',
> On Jan 19, 2014, at 3:13 PM, Simon Richard Proud <srp at geo.ku.dk> wrote:
> > Ok, that gets things a little closer - now it gives an error: "ERROR 1:
> Translating source or target SRS failed"
> > I tried with '+proj=geos +lon_0=0.0 +h=35785831' as one argument and as
> three. Same result.
> > I also tried including the -te and -tr arguments in the one argument along
> with the proj details - no luck with that either.
> > /Simon
> > Sendt: 19. januar 2014 18:05
> >> ,"-r cubicspline",
> > becomes
> > "-r", "cubicspline",
> > and so forth
> > On Jan 19, 2014, at 3:00 PM, Simon Richard Proud <srp at geo.ku.dk> wrote:
> >> Hi, thanks for the reply.
> >> I tried changing the call to this:
> >> process.call(["gdalwarp","-q","-multi","-r cubicspline","-t_srs
> '+proj=geos +lon_0=0.0 +h=35785831'","-te -5568748.2758 -5568748.4774
> 5568748.2758 5568748.2758","-tr 3000.40316582 3000.40316582","-srcnodata
> 65535","TEST.tiff","TEST2.tiff"])
> >> But still receive just the usage instructions, I can't see any other
> arguments that can be divided into an element. Setting the "shell=True"
> option also has no effect.
> >> /Simon
> >> Sendt: 19. januar 2014 17:47
> >> try
> >>> subprocess.call(["gdalwarp", "-q",  "-multi",   ...   "TEST2.tiff"])
> >> Each arg must be an element in the list.
> >> -kurt
> >> On Jan 19, 2014, at 2:27 PM, Simon Proud <srp at geo.ku.dk> wrote:
> >>> Hi,
> >>> I wish to call gdalwarp from within a python script but I cannot get it
> to
> >>> work.
> >>> The command I wish to run is:
> >>> gdalwarp -q -multi -r cubicspline -t_srs '+proj=geos +lon_0=0.0
> +h=35785831'
> >>> -te -5568748.2758 -5568748.4774 5568748.2758 5568748.2758 -tr
> 3000.40316582
> >>> 3000.40316582 -srcnodata 65535 TEST.tiff TEST2.tiff
> >>> I'm running on Ubuntu 12.04. The above command works perfectly when
> called
> >>> from a terminal window and produces a good output image.
> >>> But when I run from python I get problems.
> >>> First, I tried to run with subprocess.call(["gdalwarp","-q -multi ...
> >>> TEST2.tiff"]) then all I see is the default usage instructions. No file
> is
> >>> created. Same if I use popen.
> >>> If I use: os.system("gdalwarp -q -multi ... TEST2.tiff") then it does run
> >>> and I see the expected text on the screen. However, in this case the
> output
> >>> file is blank - it is the right size and contains the right
> georeferencing
> >>> information but every pixel in the image has a value of zero.
> >>> Does anyone have an idea what could be the problem here?
> >>> Thanks!
> >>> View this message in context:
http://osgeo-org.1560.x6.nabble.com/Problem-calling-gdalwarp-from-within-python-script-tp5098902.html
> >>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> >>> _______________________________________________
> >>> gdal-dev mailing list
> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
