[gdal-dev] Extra Decimal places added to ASCII gdal_translate mosaic
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri Jan 24 08:12:35 PST 2014
Thanks Norman. I'd already seen that page but failed to read it!
However, having tested it, it's not functioning as the manual says.
As best I can tell, DECIMAL_PRECISION=3 should give me 3 decimal places.
But what it instead does it give me 3 significant figures. So 98.354 has
become 98.3.
This becomes a problem because many of my heights are hovering around 100.
So some will either have to be 1 character too long to ensure no data loss
for the rest.
Is this a bug? The documentation on the page linked to is quite clear it
should be decimal places.
Less of an issue, but it also didn't make any difference to:
> xllcorner    432000.000000000000
> yllcorner    242000.000000000000
> cellsize     2.000000000000
GDAL 1.10.1, released 2013/08/26
Cheers,
Jonathan
On 24 January 2014 15:11, Norman Vine <nhv at cape.com> wrote:
> try
> gdal_translate -of AAIGrid -co DECIMAL_PRECISION=3  abc.vrt abc.asc
> see http://www.gdal.org/frmt_various.html
> HTH
> Norman
> On Jan 24, 2014, at 10:01 AM, Jonathan Moules <
> jonathanmoules at warwickshire.gov.uk> wrote:
> Hi List,
> I'm trying to mosaic some ASCII grid tiles into a single large ASCII file
> (which can then easily be handled).
> I'm using this process:
>> REM Create list of files
>> dir /b /s *.asc > asc_list.txt
>> REM Turn into VRT
>> gdalbuildvrt -srcnodata "-9999" -vrtnodata "0" -a_srs "EPSG:27700"
>> -input_file_list "asc_list.txt" abc.vrt
>> REM actual mosaicing
>> gdal_translate -of AAIGrid abc.vrt abc.asc
> The input files are like:
>> ncols         500
>> nrows         500
>> yllcorner     243000.000
>> cellsize      2
>> nodata_value  -9999.0
>> 98.354 98.449 98.658 98.874 99.038 99.096
> But the outputs are like:
> fncols        500
>> nrows        1000
>> NODATA_value  0
>>  98.353996276855469 98.448997497558594 98.657997131347656
>> 98.874000549316406
> Suddenly everything has a dozen extra decimal places. Not only does this
> induce the False Precision problem (we don't have heights to the
> femtometer!), it also massively increases the filesize.
> How can I get this to not happen?
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140124/8123c6ef/attachment.html>
