[gdal-dev] Can gdal_rasterize utilize OGR_STYLE?
Brian Case rush at winkey.org
Thu Jan 30 09:36:53 PST 2014
Jukka
you could use mapserver to create your image. it will make use of
ogrstyle
shp2img or if that is an issue use mapserver and the wms driver in gdal
brian
On Thu, 2014-01-30 at 15:51 +0000, Jukka Rahkonen wrote:
> Hi,
> By reading the manual page and after doing some experiments I guess that the
> answer is no. Is there any hidden parameter for burning lines with a wider
> pen than what is the default?
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
