[gdal-dev] Fast Pixel Access
Even Rouault even.rouault at mines-paris.org
Fri Jan 31 10:30:02 PST 2014
Le vendredi 31 janvier 2014 17:15:53, David Baker (Geoscience) a écrit :
> Dev's,
> I have a set of 55,501 bil files in a single directory.  They are DEMS data
> that cover the US in 7.5 minute tiles.  I would like to randomly access
> elevations at a given lat/lon's from the whole dataset.  I created a vrt
> file from the directory of bil files, and have been able to access the
> elevation at a given lat/lon using gdallocationinfo, but because of the
> size of the dataset, this operation is somewhat slow.  Can the vrt be
> indexed?
No, it isn't currently, although I think it could be improved to have a in-
memory index with moderate effort.
But are you sure the slowness is due to the lack of index ? 55,000 is a big
number, but not that big. Maybe the slowness just comes from the opening time
(XML parsing) of such a big VRT. That would need to be profiled to be sure
where the bottleneck is.
> Or, is there a faster, better way to access the pixels?  I would
> first like to do this with the utilities before diving into code (C#).
> The files are regularly named base on their location within a 1 arc-second
> grid.
> Thanks,
> David
> David M. Baker
> Senior Advisor - Geoscience Technology
> Chesapeake Energy Corporation
> david.m.baker at chk.com<mailto:david.m.baker at chk.com>
> ________________________________
> This email (and attachments if any) is intended only for the use of the
> individual or entity to which it is addressed, and may contain information
> that is confidential or privileged and exempt from disclosure under
> applicable law. If the reader of this email is not the intended recipient,
> or the employee or agent responsible for delivering this message to the
> intended recipient, you are hereby notified that any dissemination,
> distribution or copying of this communication is strictly prohibited. If
> you have received this communication in error, please notify the sender
> immediately by return email and destroy all copies of the email (and
> attachments if any).
Geospatial professional services
http://even.rouault.free.fr/services.html
