[gdal-dev] gdaltranslate and gdalwarp rotating and resizing image without being asked to, why?
Jesse McGraw jlmcgraw at gmail.com
Tue Jul 1 06:50:18 PDT 2014
On Mon, Jun 30, 2014 at 3:07 PM, Even Rouault <even.rouault at mines-paris.org>
wrote:
> That might the problem. If you create the GCPs on the PDF and not on the
> PNG,
> and that the PDF has rotation, pdftoppm I think will apply the rotation,
> hence
> the axis swapping.
Remember, I'm using the PNG I've created for all gdal operations, gdal
never interacts with the source PDF
I'm probably fundamentally misunderstanding some aspect of the command
lines I'm using in gdal*.  My end goal is to get the necessary affine
transformation information to display the PNG I create in step 3a properly
in a separate Android moving-map application (eg. your current position
displayed on the diagram as you move around the airport)
Well I'm really confused by what you are trying to do.
> For a better understanding, you should perhaps provide the PDF and all
> exact
> command lines you are typing.
Here's a step-by-step with links to relevant files for a landscape diagram
(SFO)
1. Get source PDFs from the Federal Aviation Administrator (FAA)
https://drive.google.com/file/d/0B4EbUsrclSoDeXdmM3gyV29WN0U/edit?usp=sharing
2. Run my utility.
3a. It converts the PDF to a PNG,
https://drive.google.com/file/d/0B4EbUsrclSoDMTlDZzQzeDJWU1U/edit?usp=sharing
3b. create GCPs for GDAL based on the coordinates within the PNG (hard to
see but green circles mark the GCPs chosen to correspond to the lat/lon
shown on diagram)
https://drive.google.com/file/d/0B4EbUsrclSoDWUtqNVgtWFUwa0k/edit?usp=sharing
3c.  gdal_translate the PNG file based on the GCPs we found to an
intermediate VRT
gdal_translate -q -of VRT -strict -a_srs EPSG:4326  -gcp 1017.14863049096
1800.51717680381 -122.4 37.6166666666667 -gcp 337.854728682168 1260.25
-122.383333333333 37.6333333333333 -gcp 1017.14863049095 1260.25
-122.383333333333 37.6166666666667 -gcp 1017.14863049096 720.166666666667
-122.366666666667 37.6166666666667 -gcp 337.854728682172 720.166666666667
-122.366666666667 37.6333333333333 -gcp 337.854728682172 1800.33895140302
-122.4 37.6333333333333 './dtpp/00375AD.png'
'./dtpp/CA-SFO-00375AD-PDF-AIRPORT-DIAGRAM.vrt'
https://drive.google.com/file/d/0B4EbUsrclSoDX2hzTTBsY1c5dXM/edit?usp=sharing
3d. gdalwarp the intermediate VRT to the final VRT
gdalwarp -q -of VRT -t_srs EPSG:4326 -order 1 -overwrite
''./dtpp/CA-SFO-00375AD-PDF-AIRPORT-DIAGRAM.vrt''
'./dtpp/warpedCA-SFO-00375AD.PDF-AIRPORT DIAGRAM.vrt'
https://drive.google.com/file/d/0B4EbUsrclSoDTmNDanFmbkVvVm8/edit?usp=sharing
Here's the process for a portrait one
https://drive.google.com/file/d/0B4EbUsrclSoDMjNPOVBPT01JS1U/edit?usp=sharing
2. Run my utility.
https://drive.google.com/file/d/0B4EbUsrclSoDTUZNY2RKaVVHMDQ/edit?usp=sharing
shown on diagram)
https://drive.google.com/file/d/0B4EbUsrclSoDbHNyTnhGczh3RDA/edit?usp=sharing
intermediate VRT
 gdal_translate -q -of VRT -strict -a_srs EPSG:4326  -gcp 310.408626924008
1496.72390271202 -77.3333333333333 37.5 -gcp 976.562655349203
660.697730425566 -77.3166666666667 37.5166666666667 -gcp 310.523817613394
660.744792369168 -77.3333333333333 37.5166666666667 -gcp 976.580225174465
1496.63921742496 -77.3166666666667 37.5 './dtpp/00347AD.png'
'./dtpp/VA-RIC-00347AD-PDF-AIRPORT-DIAGRAM.vrt'
https://drive.google.com/file/d/0B4EbUsrclSoDRzdVZDQzY2lZT1U/edit?usp=sharing
''./dtpp/VA-RIC-00347AD-PDF-AIRPORT-DIAGRAM.vrt''
'./dtpp/warpedVA-RIC-00347AD.PDF-AIRPORT DIAGRAM.vrt'
https://drive.google.com/file/d/0B4EbUsrclSoDRGptZFhhaVdaT1E/edit?usp=sharing
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140701/4be15736/attachment.html>
