[gdal-dev] ogr2ogr error message with OracleSpatial View to Shape
Rémy GOURRAT rgourrat at ag-carto.fr
Thu Jul 3 03:21:08 PDT 2014
When I use ogr2ogr to export data from Oracle Spatial View to shape,
With this syntax :
ogr2ogr -f "ESRI Shapefile" PARCELLE.shp OCI:ORA_USER/ORA_PWD at ORA_DATASOURCE:DGI.PARCELLE -sql "select * from DGI.PARCELLE where INSEE in (75001)" -skipfailures -overwrite
this message appears :
ERROR 1: ORA-04043: objet DGI.PARCELLE inexistant in OCIDescribeAny
This view is referenced in USER_SDO_GEOM_METADATA.
However, the export seems complete when I display it in Qgis : same geometry, same feature number than Oracle.
Is it a privilege issue or something else ?
Rémy Gourrat
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140703/dff24fdf/attachment.html>
