[gdal-dev] How retrieve the list of field of a table on spatialite in pythonlang.
Andrea Peri aperi2007 at gmail.com
Fri Jul 4 07:02:09 PDT 2014
Hi Even,
thx for response.
I found the problem.
Was a my error .
I'm quite new-by on python.
You response help me to understand that the error was mine.
Regards,
Andrea.
2014-07-03 20:59 GMT+02:00 Even Rouault <even.rouault at mines-paris.org>:
> Le jeudi 03 juillet 2014 18:01:09, Andrea Peri a écrit :
>> Hi,
>> I'm try-ing to retrieve the list of fieldname from a spatialite table.
>> To do this I try this code:
>> dataset = "select * from table1"
>> ds = driver.Open(file,False)
>> layer = ds.ExecuteSQL(dataset,None,"SQLITE")
>> layer.ResetReading()
>> layerDef = layer.GetLayerDefn()
>> In the last line I'm having an error.
> Andrea,
> Which error ? I've just tried on a spatialite db and it works fine.
>> Is the comand "GetLayerDefn" available on sqlite driver ?
> Yes, in all drivers. As soon as you have a non null layer object, you can call
> GetLayerDefn().
> Even
> Geospatial professional services
> http://even.rouault.free.fr/services.html
Andrea Peri
qwerty àèìòù
