[gdal-dev] Error with VagrantFile due to postgis-gdal dependency
Even Rouault even.rouault at mines-paris.org
Tue Jul 8 15:23:09 PDT 2014
Le mercredi 09 juillet 2014 00:13:18, Jorge Arevalo a écrit :
> Hello,
> I'm testing the VagrantFile included in GDAL trunk to create a development
> environment for GDAL, based on Vagrant. I'm following the instructions [1],
> but getting an error [2]
> Looks like the problem is the dependency between PostGIS and GDAL. The
> vagrant script tries to install PostGIS before GDAL, but PostGIS depends on
> GDAL (I think it's just a PostGIS Raster issue, not sure about it).
Jorge,
That should not be a problem. At least that was not one when I set up the
vagrant config. It is perhaps a breakage in ubuntu-gis. Perhaps you should
check with ubuntu at lists.osgeo.org if it is known.
The autotest suite needs postgis to test the PG driver.
The custom GDAL built by Vagrant is designed to replace the version that comes
with ubuntu-gis.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
