[gdal-dev] warp taking time
bas smit baspysmit at gmail.com
Thu Jul 10 04:51:54 PDT 2014
I am wondering why you are using gdalwarp for mosaicing images having same
projection instead of gdal_merge.py?
Bas Smit
On Thu, Jul 10, 2014 at 7:14 PM, Chaitanya kumar CH <chaitanya.ch at gmail.com>
wrote:
> garfy,
> Please provide the gdalwarp command you used. Did you modify GDAL_CACHEMAX?
> On Thu, Jul 10, 2014 at 3:26 PM, garfy <adiba.nizami at gmail.com> wrote:
>> Dear All,
>> I am trying to generate mosaic of 28 input images using *gdalwarp*.
>> All are in same projection. It has taken 5 days to generate the final
>> output.
>> Please find the gdalinfo of input and output attached. The input files are
>> passed to warp in the order in which the gdalinfo is present in the
>> attachement.
>> Any input on improving the time would be really helpful.
>> Thanks
>> input_files_gdalinfo.txt
>> http://osgeo-org.1560.x6.nabble.com/file/n5150453/input_files_gdalinfo.txt
>> final_output_gdalinfo.txt
>> http://osgeo-org.1560.x6.nabble.com/file/n5150453/final_output_gdalinfo.txt
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/warp-taking-time-tp5150453.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140710/baf8d386/attachment.html>
