[gdal-dev] gdal installation, geopdf not recognized
Jürgen E. Fischer jef at norbit.de
Mon Jul 14 11:17:21 PDT 2014
Hi Eli,
On Mon, 14. Jul 2014 at 10:40:08 -0700, Eli Adam wrote:
> I got this error from OSGeo4W too.  The last two lines of this page,
> http://trac.osgeo.org/osgeo4w/ticket/408, lists the mailing list and
> ticket tracker.  You can ask or report this error there.  Searching
> through trac for OSGeo4W, I found this which seems like it might be
> similar, http://trac.osgeo.org/osgeo4w/ticket/408
I can't reproduce that.  WI_Madison_West_20130722_TM_geo.pdf works fine
with both the 32 and the 64bit build in OSGeo4W (using gdal-1.11.0-2).
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
