[gdal-dev] gdal installation, geopdf not recognized
Jürgen E. Fischer jef at norbit.de
Mon Jul 14 12:35:16 PDT 2014
Hi Eli,
> > On Mon, 14. Jul 2014 at 10:40:08 -0700, Eli Adam wrote:
> >> Searching through trac for OSGeo4W, I found this which seems like it might
> >> be similar, http://trac.osgeo.org/osgeo4w/ticket/408
> > I can't reproduce that.  WI_Madison_West_20130722_TM_geo.pdf works fine
> > with both the 32 and the 64bit build in OSGeo4W (using gdal-1.11.0-2).
> Before I try updating OSGeo4W and seeing if anything changes, is there
> anything else to try to find the source of the error?  My install is
> the result of an advanced install about three months ago and probably
> updated about a month or two ago.
Ok, that's explains it.  #408 tries to explain that 1.11.0-2 is from
9 days ago and introduces pdf read support - earlier didn't have it.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
