[gdal-dev] Which format is the best identify a spatial reference ?
orel aurelien.albert at alyotech.fr
Tue Jul 15 00:45:22 PDT 2014
Spatial references objects can be imported / exported using OGR API to
multiple formats : proj4, WKT, XML...
Can I use one of these as a format "which describes properly every spatial
reference" ?
For example, if I use WKT as "internal format" for my application, is there
any chance that a projection described with a proj4 string (or an EPSG code
or whatever...) cannot be properly converted to a WKT string ?
My goal is to use a single spatial reference format when storing/loading
work sessions of my application.
Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Which-format-is-the-best-identify-a-spatial-reference-tp5151074.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
