[gdal-dev] Unable to Rotate Image uisng setGeoTransform
Pratap Chelamilla pratap.chelamilla at amigooptima.in
Wed Jul 16 05:32:11 PDT 2014
How to rotate an image with different angles(such as 30 ,45 60 .....
degress) using SetGeoTransform?
I have tried setting newTie[2] =45 degree  and  newTie[2] =
(45.0*3.1415926)/180) in radians
 double *newTie = new double[6];
            newTie[0] = tie[0] + (xPos*tie[1]);              /*
adfGeoTransform[0] /* top left x */
            newTie[3] = tie[3] + (yPos*tie[5]);             /*
adfGeoTransform[3] /* top left y */
            newTie[1] = tie[1];                         /*
adfGeoTransform[1] /* w-e pixel resolution */
            newTie[2] = 45.0;                         /* adfGeoTransform[2]
/* rotation, 0 if image is "north up" */
            newTie[4] = 45.0;                     /*    adfGeoTransform[4]
            newTie[5] = tie[5];                  /*   adfGeoTransform[5] /*
n-s pixel resolution */
But,SetGeoTransform is not affecting any change on image after writing with
RasterIO (unable to see any rotated image),Image is georeferenced.
What values should I use for  adfGeoTransform[2]/newTie[2] and
adfGeoTransform[4]/newTie[4]?
Thanks,
Pratap.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140716/c7ca8bb3/attachment.html>
