[gdal-dev] ogr2ogr OCI to shape : Multipolygon (Oracle Gtype = 7 ) not supported ?
Even Rouault even.rouault at mines-paris.org
Wed Jul 16 15:27:37 PDT 2014
Rémi,
You need to create an OSGeo id as described in
http://www.osgeo.org/osgeo_userid/
As far as your issue is concerned, indeed there's not yet general support for
curved geometries in OGR. Looking at the OCI driver, I can see code to do the
stroke of circular arcs as polylines in the polygon case, but there's perhaps
indeed something missing to support the multipolygon case with circular arcs.
Best regards,
Even
> I try to make a Track ticket for enhancement of ogr2ogr for Oracle Gtype =
> 7 and the curves
> But I can't login me, each time, it said to me I don't have the create
> ticket privilege.
> How to get this privilege ?
> or someone can do it for me ?
> thanks for your help
> Rémy
> De : gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] De la part de Rémy GOURRAT
> Envoyé : mercredi 16 juillet 2014 18:23
> À : gdal-dev at lists.osgeo.org
> Objet : Re: [gdal-dev] ogr2ogr OCI to shape : Multipolygon (Oracle Gtype =
> 7 ) not supported ?
> Solved ! i get the issue and the workaround of my problem.
> When you use ogr2ogr to translate a Oracle Gtype = 3 (simple Polygon with
> hole or not) to a shapefile and this polygon have some curves like by
> example after a buffer treatment (it's Ok in SDO_GEOMETRy), Ogr2ogr indent
> curves in many little polyline.
> Translation in shapefile is ok.
> But When you use ogr2ogr to translate an Oracle Gtype = 7 (multi-Polygon
> with hole or not, with at less 2 exteriors rings) to a shape and this
> polygon have some curves like by example after a buffer treatment (it's Ok
> in SDO_GEOMETRY), Ogr2ogr don't indent curves in many little polyline.
> Translation in shapefile seems ok, without errors message but the Geometry
> in the fileshape is never writing.
> It's normal because Shapefile don't enjoy curves.
> So i modified my Oracle query like this :
> Old Version :
> sdo_geom.sdo_buffer(SDO_AGGR_CONCAT_LINES(sdo_util.rectify_geometry(GEOMETR
> Y,0.001) ),50,0.001)
> New Version :
> SDO_GEOM.SDO_ARC_DENSIFY(sdo_geom.sdo_buffer(SDO_AGGR_CONCAT_LINES(sdo_uti
> l.rectify_geometry(GEOMETRY,0.001)),50,0.001),0.001,'arc_tolerance=1')
> SDO_GEOM.SDO_ARC_DENSIFY : indent curves in many little polyline for Gtype
> = 3 or 7
> So ogr2ogr is always Ok to translate in ShapeFile.
> Rémy
> De :
> gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>
> Envoyé : mardi 15 juillet 2014 13:44
> À : gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
> Objet : [gdal-dev] ogr2ogr OCI to shape : Multipolygon (Oracle Gtype = 7 )
> not supported ?
> Hi,
> I try to export in shape a buffer from union of lines.
> I validated this query in Sqldevelopper before use it with Ogr :
> "select '1' as
> "FID",sdo_geom.sdo_buffer(SDO_AGGR_CONCAT_LINES(sdo_util.rectify_geometry(
> GEOMETRY,0.001) ),50,0.001) as geometry from assc"
> After created this geometry in oracle temporary table, I can display it
> without issue in Autocad Map with Fdo Oracle Provider.
> With ogr2ogr, Shape is created but when I open with Qgis i see 1 attribute
> line (it's Ok) but i don't see geometry on the map and the shape size is
> only 1ko.
> This is my command line :
> ogr2ogr -f "ESRI Shapefile" c:\temp\ASSC.shp
> OCI:[username]/[password]@[instance] -sql "select '1' as
> GEOMETRY,0.001) ),50,0.001) as geometry from assc" -skipfailures -overwrite
> -dim 2
> it's running well and no issue in debug mode :
> OGR2OGR: 1 features written in layer 'ASSC'
> OCI: 1 features read on layer 'select 'EU01'...
> If I don't use SDO_AGGR_CONCAT_LINES in my query wich create the unique
> multi-polygon (Oracle Gtype = 7), the shape is created too and I can see
> more 2000 buffer polygon geometry (Oracle Gtype = 3) in Qgis.
> "FID",sdo_geom.sdo_buffer(sdo_util.rectify_geometry(GEOMETRY,0.001),50,0.0
> 01) as geometry from assc" -skipfailures -overwrite -dim 2
> So I ask me the question is there a issue with ogr2ogr with Oracle
> Multipolygon (Gtype = 7) ?
> Is there a work around ?
> Thanks
> Rémy
> This message has been scanned for viruses and
> dangerous content by MailScanner<http://www.mailscanner.info/>, and is
> believed to be clean.
Geospatial professional services
http://even.rouault.free.fr/services.html
