[gdal-dev] Lambert 93 problem with GDAL 1.11.0
orel aurelien.albert at alyotech.fr
Thu Jul 17 23:36:58 PDT 2014
Thanks for spotted this, but it doesn't change anything.
I've uploaded the file here :
http://speedy.sh/vNEcQ/test-bati-pts2.zip
<http://speedy.sh/vNEcQ/test-bati-pts2.zip>
If I display it, using GlobalMapper for example (or my osgEarth based
application), the data are in the right place.
If I reproject it using "ogr2ogr -t_srs" to EPSG:4326 or EPSG:3857 (or any
other I guess) the point are then moved by more than 100 km.
I've try to fix the WKT in the prj file, or even replace it using "ogr2ogr
-a_srs EPSG:2154", but always with the same result.
It seems very strange to me since osgEarth dispy it proerly and osgEarth is
based on GDAL. I don't if GlobalMapper is also based on GDAL, but it siplay
it properly too.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Lambert-93-problem-with-GDAL-1-11-0-tp5151515p5151654.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
