[gdal-dev] Write support for MBTiles driver
Etienne Tourigny etourigny.dev at gmail.com
Sat Jul 19 10:22:33 PDT 2014
Note that the licence used in the software (GNU GPL v3) is incompatible
with GDAL, so it cannot be included in the GDAL source tree without the
author's consent to use the code under another licence (such as the MIT/X
licence used by GDAL).
On Sat, Jul 19, 2014 at 10:15 AM, Nicu Tofan <nicu.tofan at gmail.com> wrote:
> Thanks, I'll have a look,
> I see that Simon Thépot is mentioned as author and Mark Johnson adapted
> them.
> Nick
> 2014-07-19 15:47 GMT+03:00 Eli Adam <eadam at co.lincoln.or.us>:
>> http://geopaparazzi.github.io/geopaparazzi/ has write support built in
>> as part of caching. I think that Mark is the person who added the MBTiles
>> write support to Geopaparazzi.
>> Best regards, Eli
>> On Fri, Jul 18, 2014 at 12:07 PM, Nicu Tofan <nicu.tofan at gmail.com>
>> wrote:
>> > Hello,
>> > I would like to draw your attention to this ticket created by me:
>> > http://trac.osgeo.org/gdal/ticket/5578
>> > Here is its content:
>> >> In version 1.11.0 gdal provides a read-only driver for MBTiles thanks
>> to
>> >> the work of Even Rouault.
>> >> For the application that I'm working on I need to create MBTiles files
>> >> and
>> >> I would like to make my work part of gdal's driver.
>> >> If there are other efforts in this direction I would love to help.
>> >> References:
>> >> MBTiles http://mbtiles.org/
>> >> MBTiles Specification https://github.com/mapbox/mbtiles-spec
>> >> Implementations
>> >> https://github.com/mapbox/mbtiles-spec/wiki/Implementations
>> >> Driver Page on gdal http://www.gdal.org/frmt_mbtiles.html
>> >> gdal2mb script https://github.com/developmentseed/gdal2mb
>> >> MBTilesGenerator PHP library
>> https://github.com/HTML24/mbtiles-generator
>> >> MBUtil Python package https://github.com/klokantech/mbutil
>> >> mbtiler.cpp from MapBox
>> >> https://github.com/mapbox/mbtiler/blob/master/mbtiler.cpp
>> >> ReaderWriterMBTiles.cpp from osgearth
>> http://updraft.github.io/osgearth-doc/html/ReaderWriterMBTiles_8cpp_source.html
>> > Thanks,
>> > Nick
>> > _______________________________________________
>> > gdal-dev mailing list
>> > gdal-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140719/91bb52ca/attachment.html>
