[gdal-dev] Write support for MBTiles drive
Nicu Tofan nicu.tofan at gmail.com
Mon Jul 21 09:48:32 PDT 2014
Thank you all for your input. I will start the work later this week and I
will keep you posted about the progress. Also, thanks for your support and
comments, Mark.
I haven't had the time yet to read the guidelines for developers (regarding
style & workflow & all) but I will make sure I do that before doing any
work. I was thinking about manually forking the gdal source on GitHub,
doing the work there, and, when done, submitting a patch for review.
Regards,
Nick
2014-07-21 16:12 GMT+03:00 Mark Johnson <mj10777 at googlemail.com>:
> >> Note that the licence used in the software (GNU GPL v3) is incompatible
> >> with GDAL, so it cannot be included in the GDAL source tree without the
> >> author's consent to use the code under another licence (such as the MIT/X
> >> licence used by GDAL).
> If geopaparazzi was meant by this, we have no objection for anyone to use this code.
> https://github.com/geopaparazzi/geopaparazzi/issues/189
> Our class was based on the original work of 'Simon Thépot'
> - which had a minimal reading logic only
> I made some needed corrections and developed the writing logic.
> There is also a python implementation
> - class MbTiles
> that can be found at:
> https://github.com/mj10777/mapmbtiles/blob/master/mapmbtiles/mbtiles.py
> This was an attempt to adapt the last public version of gdal2tiles.py before it became a closed source from the original author.
> - goal was to be able to store the results of gdal2tiles directly in a mbtiles file
> there are one or two functions based on other sources (and documented as such),
> but otherwise a python version of the geopaparazzi version.
> At
> http://wiki.openstreetmap.org/wiki/Slippy_map_tilenames#tileinfo.sh
> there is a bash version that also creates mbtiles that I wrote.
> All of these versions create mbtiles with
> - view/table logic as done by tilemill
> -- making it possible that 'blank' image are only stored once
> --- blank being all 256x256 have the same rgb value
> If there are any questions, fell free to open an issue at
> Mark Johnson, Berlin Germany
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140721/0ca7beb1/attachment.html>
