[gdal-dev] Upgrading Version Not Working
Even Rouault even.rouault at mines-paris.org
Thu Jul 24 14:26:58 PDT 2014
Le jeudi 24 juillet 2014 23:21:52, Nelson, Nicole a écrit :
> Even,
>    Is it possible that I am missing an external library? Do you know which
> external libraries would be required to accomplish such a task?
It might be related to have built GDAL against GEOS or not. Although I would
still expect it to work in the non-GEOS case. Did you try the sample I
provided ?
> Thanks,
> Nicole
> On 7/24/14, 1:03 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
> >Le jeudi 24 juillet 2014 21:49:19, Nelson, Nicole a écrit :
> >> Hello,
> >>    I am working on an application which was developed by another
> >>developer
> >> about 2 years ago. At the time the developer used GDAL 1.9.1. I am
> >>trying
> >> to upgrade to the latest version of GDAL (1.11.0). However, I am not
> >>able
> >> to get the same functionality to work. I am reading in a shape file with
> >> ogr.Open which is successful. Then I am able to get a layer
> >>successfully.
> >> On that layer I try to apply a spatial filter with a single point
> >>geometry
> >> representing a latitude and longitude pair. However, when I call
> >> GetNextFeature I always get null, regardless of the input. The
> >> GetNextFeature function previously returned at least one feature. Did
> >> something change in the versions that I may have missed?
> >Nicole,
> >Single point spatial filter must be an odd use case. Not sure this is
> >present
> >in our regression tests, so that might have been accidentaly broken.
> >However I
> >just made an experiment with GDAL trunk :
> >$ cat square.csv
> >id,WKT
> >1,"POLYGON((0 0,0 1,1 1,1 0,0 0))"
> >$ ogr2ogr square.shp square.csv
> >$ ogrinfo square.shp -al -spat 0.25 0.5 0.25 0.5
> >INFO: Open of `square.shp'
> >      using driver `ESRI Shapefile' successful.
> >Layer name: square
> >Geometry: Polygon
> >Feature Count: 1
> >Extent: (0.000000, 0.000000) - (1.000000, 1.000000)
> >Layer SRS WKT:
> >(unknown)
> >WKT: String (80.0)
> >OGRFeature(square):0
> >  id (String) = 1
> >  WKT (String) = POLYGON((0 0,0 1,1 1,1 0,0 0))
> >  POLYGON ((0 0,0 1,1 1,1 0,0 0))
> >So at least on that example it seems to work.
> >> Is there
> >> something that would make GetNextFeature return null, but GetFeature at
> >> various indices return values?
> >Yes, GetFeature() doesn't take into account the spatial filter.
> >Best regards,
> >Even
Geospatial professional services
http://even.rouault.free.fr/services.html
