[gdal-dev] gdal gml driver field type
Martin Landa landa.martin at gmail.com
Fri Jul 25 02:44:19 PDT 2014
Hi Even,
2014-07-24 21:49 GMT+02:00 Even Rouault <even.rouault at mines-paris.org>:
> OGR integers are only 32 bit wide for now. There's a draft RFC about
> introducing 64 bit integers. Pending from being complemented and implemented.
ah, I thought that `width` for integers has some effect.
> In the meantime, you will have to declare the type as String.
OK, thanks. I will fix GFS files in this way. Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
