[gdal-dev] feature style from dxf don't escape the apostrofe
Andrea Peri aperi2007 at gmail.com
Sun Jul 27 23:48:34 PDT 2014
after some tests I see that the apostrophe is not necessary to be
escaped because it s not a special char.
Regards,
A.
2014-07-27 23:53 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi, reading better the featurestyle specs,
> http://www.gdal.org/ogr_feature_style.html
> I'm relly not sure if is necessary to escape the apostrophe in the texts.
> A.
> 2014-07-27 21:59 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>> Hi,
>> I'm testing the featurestyle filed loaded on a spatialite from a set of dxf.
>> When the dxf has a apostrophe char (')
>> it is loaded as is in the style field without an escape.
>> As example, I have this situation:
>> LABEL(f:"Arial",t:"'99",a:305,s:2.4g,c:#000000)
>> Instead of
>> LABEL(f:"Arial",t:"\'99",a:305,s:2.4g,c:#000000)
>> I test it with mapserver new styleitem feature.
>> I see the
>> give an error, instead the
>> Is correctly mapped.
>> Is this (don't escaping apostrophe char ) a bug of gdal dxf driver ?
>> Thx,
>> Andrea Peri
>> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
