[gdal-dev] Does gdal_calc.py not calculate arithmetic with in the same file?
Cleo Drakos cleo21drakos at gmail.com
Tue Jul 29 07:04:04 PDT 2014
Thanks for your response.
I tried the followings:
gcalc = 'C:\\Users\\cleo\\Documents\\gdalpys\\gdal_calc.py'
##I produced second file (b)as the copy of first(a)
a = 'D:\\a.tif'
b = 'D:\\b.tif'
outfile = 'D:\\result.tif'
expr = '(A-B)/(A+B)'
subprocess.call([sys.executable,gcalc,'-A',a,'--A_band','1','-B',b,'--B_band','0','--outfile',outfile,\
    '--calc',expr,'--type','Float32','--format','ENVI'],shell=True)
a,b,outfile = None, None,None
Unfortunately, resulted file is completely black.
I hope someone can help me.
On Tue, Jul 29, 2014 at 10:37 PM, Etienne Tourigny <etourigny.dev at gmail.com>
wrote:
> I am not sure, but you can do the following to make sure:
> cp infile infile2
> gdal_calc.py -A infile --A_band 1 -B infile2 --B_band 0 --outfile outfile
> --calc "(A-B)/(A+B)"
> Also, perhaps the extra comma in your command might be to blame "-B
> infile,"
> Etienne
> On Tue, Jul 29, 2014 at 3:46 AM, Cleo Drakos <cleo21drakos at gmail.com>
> wrote:
>> Hi GDAL Developers,
>> I have one GeoTIFF file with 2 bands. The data type is Byte. I want to
>> calculate (Band2-Band1)/(Band2+Band1).
>> But the following command provided a dark image:
>> gdal_calc.py -A infile --A_band 1 -B infile, --B_band 0 --outfile outfile
>> Thanks for your time.
>> cleo
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140729/93322117/attachment-0001.html>
