[gdal-dev] Problem with BIL files and GDAL
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Wed Jul 30 03:58:44 PDT 2014
Since we are here, you could re-run gdalinfo -stats on your dataset. (Maybe
you see a black image due to a dynamic concentrated on low values).
Moreover you may consider using the "-scale" option on gdal_translate to
scale your values to byte or make sure to preserve the output type with the
option "-OT UInt16".
Honestly, I don't remember if PNG support 16 bits (But would say "yes") and
if the tool/browser/what else you will use to open it will show you
correctly.
Hope this helps.
Regards,
Daniele
http://goo.gl/NWWaa2 for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
On Wed, Jul 30, 2014 at 12:26 PM, Belén <beln1 at hotmail.com> wrote:
> Hi Daniele,
> Thank you for your answer.
> This is the output of gdalinfo:
> Driver: EHdr/ESRI .hdr Labelled
> Files: prueba.bil
>           prueba.hdr
> Size is 4000, 4000
> Coordinate System is `'
> Origin = (504815.000000000000000,4766395.000000000000000)
> Pixel Size = (10.000000000000000,-10.000000000000000)
> Corner Coordinates:
> Upper Left  (  504815.000, 4766395.000)
> Lower Left  (  504815.000, 4726395.000)
> Upper Right (  544815.000, 4766395.000)
> Lower Right (  544815.000, 4726395.000)
> Center      (  524815.000, 4746395.000)
> Band 1 Block=4000x1 Type=UInt16, ColorInterp=Undefined
> Thank you again!!
> Regards.
> Belén Muñoz.
> From: daniele.romagnoli at geo-solutions.it
> Date: Wed, 30 Jul 2014 12:20:09 +0200
> Subject: Re: [gdal-dev] Problem with BIL files and GDAL
> To: beln1 at hotmail.com
> CC: gdal-dev at lists.osgeo.org
> Hi,
> could you run a gdalinfo on your origin file and provide us the output?
> Wondering if its datatype is float and a straight gdal_translate (without
> scaling applied) truncate all values when going to Byte PNG.
> Cheers,
> Daniele
> GeoServer Professional Services from the experts! Visit
> GeoSolutions S.A.S.
> Italy
> http://twitter.com/geosolutions_it
> On Wed, Jul 30, 2014 at 11:22 AM, Belén <beln1 at hotmail.com> wrote:
> Hello!
> My name is Belén and i'm trying to convert a .bil file (.bil and .hdr) to
> a .png using gdal_translate, it seems to work fine, there are no error
> messages but when I open the .png file, I only have a big completely black
> square.
> There's some special thing I should be doing? I'd appreciate any help,
> because I'm completely lost.
> Thank you very much in advance.
> Regards.
> Belén Muñoz.
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140730/337bf2b7/attachment.html>
