[gdal-dev] Unable to identify feature at selected position with gdal.1.11 with geos-3.4.2
pratap chelamilla pratap.chelamilla at amigooptima.in
Wed Jul 30 05:28:23 PDT 2014
Hi ,
Unable to identify feature at selected Position,Earlier Version of gdal 1.9
with geos-3.1.1 Working fine, But I have build the newer version gdal-1.11
with geos-.3.4.2, It is identifying the feature but not exactly at the same
place, it is showing feature from different position.
There's some special thing I should be doing? I'd appreciate any help.
Thank you very much in advance.
GDAL_VER='1.11.0'
GDAL_VERSION_MAJOR='1'
GDAL_VERSION_MINOR='11'
GDAL_VERSION_REV='0'
GEOS_CFLAGS='-I/d/gdal/geos-3.4.2_build/include'
GEOS_CONFIG='/d/gdal/geos-3.4.2_build/bin/geos-config'
GEOS_LIBS='-L/d/gdal/geos-3.4.2_build/lib -lgeos_c'
Regards,
Pratap.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Unable-to-identify-feature-at-selected-position-with-gdal-1-11-with-geos-3-4-2-tp5154190.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
