[gdal-dev] Unable to identify feature at selected position with gdal.1.11 with geos-3.4.2
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Jul 30 21:56:22 PDT 2014
Pratap,
Can you provide a code snippet? Is this happening for every data source?
How far is the other feature? Is the distance consistent?
On Wed, Jul 30, 2014 at 5:58 PM, pratap chelamilla <
pratap.chelamilla at amigooptima.in> wrote:
> Hi ,
> Unable to identify feature at selected Position,Earlier Version of gdal 1.9
> with geos-3.1.1 Working fine, But I have build the newer version gdal-1.11
> with geos-.3.4.2, It is identifying the feature but not exactly at the same
> place, it is showing feature from different position.
> There's some special thing I should be doing? I'd appreciate any help.
> Thank you very much in advance.
> GDAL_VER='1.11.0'
> GDAL_VERSION_MAJOR='1'
> GDAL_VERSION_MINOR='11'
> GDAL_VERSION_REV='0'
> GEOS_CFLAGS='-I/d/gdal/geos-3.4.2_build/include'
> GEOS_CONFIG='/d/gdal/geos-3.4.2_build/bin/geos-config'
> GEOS_LIBS='-L/d/gdal/geos-3.4.2_build/lib -lgeos_c'
> Regards,
> Pratap.
> http://osgeo-org.1560.x6.nabble.com/Unable-to-identify-feature-at-selected-position-with-gdal-1-11-with-geos-3-4-2-tp5154190.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140731/29d81be0/attachment.html>
