[gdal-dev] Reading contents of Erdas Block File
Ryan troll1602 at gmail.com
Tue Jun 3 12:43:29 PDT 2014
Looking around the source for the HFA driver I was able to find
hfatest.cpp. I compiled that and got what I needed with the -dt option.
Problem solved!
-Ryan
On Fri, May 30, 2014 at 9:10 AM, Ryan <troll1602 at gmail.com> wrote:
> Erdas has some example data:
> http://download.intergraph.com/downloads/imagine-photogrammetry-and-lps-example-data
> It's a large zip (~900Mb) so I attached just the important image/block
> file/doc.
> -Ryan
> On Fri, May 30, 2014 at 12:51 AM, Even Rouault <
> even.rouault at mines-paris.org> wrote:
>>  On Thursday 29 May 2014 16:42:35 Ryan wrote:
>> > There is a set of images (a handful of .img) and only one block file. I
>> can
>> > open any of the images but that doesn't seem to access the metadata
>> that's
>> > stored on the block file.
>> Access to the .blk and one of the .img could be useful for investigation.
>> > -Ryan
>> > On Thu, May 29, 2014 at 3:24 PM, Even Rouault <
>> > wrote:
>> > > On Thursday 29 May 2014 12:41:17 Ryan wrote:
>> > > > I have some imagery that has metadata stored in Erdas Block Files
>> (.blk)
>> > > > that I am having a hard time reading.
>> > > > It likes the data is stored in an HFA Header, when viewing the file
>> (cat
>> > > or
>> > > > less) it begins with "EHFA_HEADER_TAG".
>> > > > However, there are no raster bands so using gdalinfo or GDALOpen
>> errors
>> > > out
>> > > > with:
>> > > > ERROR 1: Unable to open image_name_file.blk, it has zero usable
>> bands.
>> > > Did you try opening the main file, the .img ?
>> > > > Any ideas on reading this kind of file?
>> > > > -Ryan
>> > > Geospatial professional services
>> > > http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140603/6446ef7b/attachment.html>
