[gdal-dev] Convert raster into points with GDAL?
Even Rouault even.rouault at mines-paris.org
Wed Jun 4 04:54:53 PDT 2014
Hi Jukka,
At least two ways of turning a raster into a grid of poinds :
* gdal2ogr mentionned in http://trac.osgeo.org/gdal/wiki/CodeSnippets. You need
to compile it from source.
* Otherwise http://svn.osgeo.org/gdal/trunk/gdal/swig/python/scripts/gdal2xyz.py
. With the -csv option, it will create a CSV file.
Even
> Hi,
> Is there a tool for converting rasters into vector grids, either points or
> polygons? I know gdal_polygonize but what I am after would just create a
> regular grid of points or polygons and write raster values into attributes.
> I can do that with SEXTANTE vectorization tools but I would rather use GDAL.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
