[gdal-dev] GSoC 2014 Weekly Report 3 : Implement write support for GDAL PostGIS Raster driver for GDAL
Varun Saraf varunsaraf14 at gmail.com
Fri Jun 6 13:14:32 PDT 2014
Below is my third weekly report:
*What did I do this week?*
   - Modified the PostGISRasterRasterBand::IRasterIO method, enabling it to
   process the buffer(pData) containing the raster data for write
   mode(GF_Write). After the datatype conversion it is ready to be written to
   the query. In the meanwhile, I realized that while inserting a raster in a
   table it is always broken into evenly sized tiles. So the default
   implementation of GDALRasterBand::IRasterIO can be possibly used to handle
   the write case.
   - Implemented PostGISRasterDataset::InsertRecords method which creates
   the insert query.
*What do I plan on doing next week?*
   - Continue to write methods to create the sql query which will write
   data to the PostgreSQL tables.
*Am I blocked on anything?*
   - No.
Link to weekly report :
https://github.com/varunsaraf/postgis_raster/wiki/Report-3
Link to code repository : https://github.com/varunsaraf/postgis_raster
More details at : http://trac.osgeo.org/gdal/wiki/PostGIS_raster_driver
Regards,
Varun Saraf
Lab for Spatial Informatics
IIIT Hyderabad, India
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140607/6b882276/attachment.html>
