[gdal-dev] Control overview block size
Etienne B. Racine etiennebr at gmail.com
Tue Jun 10 05:38:03 PDT 2014
Hi List,
Is there a way to control the block size of overviews and inspect that
block size from gdalinfo ?
I have a raster with 256x256 block size.
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
I'm trying to feed the images to a program that seemingly supports Tiffs
with internal overview of the same block size than the image.
I've tried >gdaladdo --config BLOCKXSIZE 256 --config BLOCKYSIZE 256
image.tif 2 4 8 16 32
gdalinfo:
  Overviews: 8655x5655, 4328x2828, 2164x1414, 1082x707, 541x354
But I couldn't find a way to inspect the overview block size to confirm
they are 256x256 since I get the same results if I set BLOCKSIZE to 128. I
suspect these options are ignored in gdaladdo.
Any way I can 1) control the overview block size and 2) inspect the block
size ?
Thanks for your help,
Etienne
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140610/82838d66/attachment.html>
