[gdal-dev] GDAL may create slow GPKG/SQLite indexes
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Jun 10 11:31:12 PDT 2014
Even Rouault <even.rouault <at> mines-paris.org> writes:
> Jukka,
> I tried to simulate your scenario but couldn't observe any performance
> difference (on Linux, but I doubt that the OS would make a difference) when
> generating a test DB with 3.7.9 or 3.7.14, and using it with the other
> version.
> However it might heavily depend on the number of records that match
> attr_1='009' and area>1000
> Could you share your DB ?
I created a new one for you. It was a bit irritating job because the speed
test results are not at all stable. I suppose that same cachign may occur
here and there. However, this one in now very slow (for example 500 seconds)
with OpenJUMP which reads data from java through sqlite-jdbc-3.7.2.jar. Same
query from ogrinfo tends to take around 25 s and when I made a copy of the
db, dropped and created indexes again with spatialite-gui the query takes
about 0.2 s. However, this procedure did not make ogrinfo faster. Running
ANALYZE and VACUUM did not make a big difference for me.
select * from indextest
where knro='781'
or pinta_ala>1000;
http://hip.latuviitta.org/tiedostot/indextest.zip
-Jukka Rahkonen-
