[gdal-dev] VRTDataset in Java
Even Rouault even.rouault at mines-paris.org
Tue Jun 10 23:43:48 PDT 2014
> The VRT driver is the usual solution to a lot of problem but we cannot
> automatize the solution on environment other than C/C++ or command
> scripts. But unfortunately, even if we add those two function much of the
> VRT magic is still not on the VRT code but in gdal_translate.cpp [0].
Yes, some added value still is in the utilities. An idea that has floated
around and could be a potential solution for this would be to put the utility
code in the library itself and have it mapped as a C API that could also be
used from SWIG bindings.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
