[gdal-dev] OGR writing problem pl. help
user gdal userofgdal at gmail.com
Wed Jun 11 06:23:41 PDT 2014
Dear all,
I have a shape file and programmatically I have to write to an attribute
named 'production'. I use Visual; C++ 2005. I proceeded like this:
const char *DriverName = "ESRI Shapefile";
OGRSFDriver *Driver;
OGRRegisterAll();
Driver = OGRSFDriverRegistrar::GetRegistrar( )->GetDriverByName(DriverName);
if(!Driver)
 AfxMessageBox(_T("Driver Conf. failed"));
 (CMyApp *) AfxGetMainWnd( )->PostMessage(WM_CLOSE);
OGRDataSource *outsource;
OGRLayer *outlayer; OGRFeature *outfeature;
outsource=OGRSFDriverRegistrar::Open(chOutShapeFile, TRUE); /* char
*chOutShapeFile */
outlayer=outsource->GetLayer(0);
outfeature=outlayer->GetFeature(0);
 /* Create a field names production */
OGRFieldDefn prfield("production", OFTReal);  /* Want to write decimal
quantities */
prfield.SetWidth(32);
if(outlayer->CreateField(&prfield)!=OGRERR_NONE)
 AfxMessageBox(_T("Field named production could not be created"));
 while(outfeature)  // Get the first feature
  Prod=CalcProduction(...);
  outfeature->SetField("production", FALL->Production);
  outfeature=outlayer->GetNextFeature( );
In the destructor: if(outsource)
OGRDataSource::DestroyDataSource(outsource);
My doubts are these:
1. At the end I find no change in the shape file. What could have gone
wrong?
2. I tried to read attributes (for example, area/shape_area). All incorrect
reads. How to tame the computer?
3. The shape file  contains only a handfull of polygons (which I checked
with ARC GIS/ERDAS) but to my horror the  MFC/Visual C++  program says
there are > 1000 features.
With many thanks,
Yours sincerely,
  B. Ramesh
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140611/3efe1582/attachment.html>
