[gdal-dev] gdaltindex with wildcard (*.tif) in a /vsizip/myzip.zip
Helmut Kudrnovsky hellik at web.de
Fri Jun 13 11:18:55 PDT 2014
>> gdaltindex doq_index.shp doq/*.tif
>Wildcard is evaluated by the operating system
ah yes, your are right.
>An alternative might be to use the gdal_ls.py sample utility
>(http://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/gdal_ls.py),
>redirect its output to a file and specify this file with --optfile to the
>gdaltindex command line.
thanks, gdal_ls.py works nicely.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdaltindex-with-wildcard-tif-in-a-vsizip-myzip-zip-tp5145801p5145822.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
