[gdal-dev] Cmake for building GDAL
Dmitriy Baryshnikov bishop.dev at gmail.com
Tue Jun 17 06:58:05 PDT 2014
Hi All,
I just fix Cmake scripts for current GDAL trunk and make GDAL on my
Ubuntu 14.04. Last code is in cmake4gdal brunch on github
(https://github.com/nextgis/gdal-svn/tree/cmake4gdal).
Now it tested on Windows (32-bit and 64-bit builds) and Linux (Ubuntu 14.04).
There are no all parts of GDAL (some drivers, bindings and so on), but
this is maybe some kind of first look.
The work is going on, so I plan fix all this issues. You can test this.
Maybe there are some error with naming conventions and install paths.
Also I set the drivers which reported as build by default as ON in Cmake
(http://gdal.org/formats_list.html  and
http://gdal.org/ogr_formats.html). The others can be switched on bu
CMake-GUI or command line.
My GDAL build includes:
$ ogrinfo --formats
Supported Formats:
    ESRI Shapefile -vector- (rw+v): ESRI Shapefile
    MapInfo File -vector- (rw+): MapInfo File
    S57 -vector- (rw+v): IHO S-57 (ENC)
    OGR_VRT -vector- (rov): VRT - Virtual Datasource
    Memory -vector- (rw+): Memory
    CSV -vector- (rw+v): Comma Separated Value (.csv)
    GML -vector- (rw+v): Geography Markup Language (GML)
    GPX -vector- (rw+v): GPX
    LIBKML -vector- (rw+v): Keyhole Markup Language (LIBKML)
    KML -vector- (rw+v): Keyhole Markup Language (KML)
    GeoJSON -vector- (rw+v): GeoJSON
    GPKG -vector- (rw+v): GeoPackage
    SQLite -vector- (rw+v): SQLite / Spatialite
    PostgreSQL -vector- (rw+): PostgreSQL/PostGIS
    MySQL -vector- (rw+): MySQL
    OpenFileGDB -vector- (rov): ESRI FileGDB
    DXF -vector- (rw+v): AutoCAD DXF
    WFS -vector- (rov): OGC WFS (Web Feature Service)
    SXF -vector- (ro): Storage and eXchange Format
$ gdalinfo --formats
Supported Formats:
    VRT -raster- (rw+v): Virtual Raster
    GTiff -raster- (rw+vs): GeoTIFF
    HFA -raster- (rw+v): Erdas Imagine Images (.img)
    PNG -raster- (rwv): Portable Network Graphics
    JPEG -raster- (rwv): JPEG JFIF
    MEM -raster- (rw+): In Memory Raster
    GIF -raster- (rwv): Graphics Interchange Format (.gif)
    BIGGIF -raster- (rov): Graphics Interchange Format (.gif)
    BMP -raster- (rw+v): MS Windows Device Independent Bitmap
    DIMAP -raster- (rov): SPOT DIMAP
    TIL -raster- (rov): EarthWatch .TIL
    WMS -raster- (rwvs): OGC Web Map Service
    MAP -raster- (rov): OziExplorer .MAP
    PNM -raster- (rw+v): Portable Pixmap Format (netpbm)
    DOQ1 -raster- (rov): USGS DOQ (Old Style)
    DOQ2 -raster- (rov): USGS DOQ (New Style)
    ENVI -raster- (rw+v): ENVI .hdr Labelled
    EHdr -raster- (rw+v): ESRI .hdr Labelled
    GenBin -raster- (rov): Generic Binary (.hdr Labelled)
    PAux -raster- (rw+): PCI .aux Labelled
    MFF -raster- (rw+): Vexcel MFF Raster
    MFF2 -raster- (rw+): Vexcel MFF2 (HKV) Raster
    FujiBAS -raster- (ro): Fuji BAS Scanner Image
    GSC -raster- (rov): GSC Geogrid
    FAST -raster- (rov): EOSAT FAST Format
    BT -raster- (rw+v): VTP .bt (Binary Terrain) 1.3 Format
    LAN -raster- (rw+v): Erdas .LAN/.GIS
    CPG -raster- (ro): Convair PolGASP
    IDA -raster- (rw+v): Image Data and Analysis
    NDF -raster- (rov): NLAPS Data Format
    EIR -raster- (rov): Erdas Imagine Raw
    DIPEx -raster- (rov): DIPEx
    LCP -raster- (rwv): FARSITE v.4 Landscape File (.lcp)
    GTX -raster- (rw+v): NOAA Vertical Datum .GTX
    LOSLAS -raster- (rov): NADCON .los/.las Datum Grid Shift
    NTv2 -raster- (rw+vs): NTv2 Datum Grid Shift
    CTable2 -raster- (rw+v): CTable2 Datum Grid Shift
    ACE2 -raster- (rov): ACE2
    SNODAS -raster- (rov): Snow Data Assimilation System
    KRO -raster- (rw+v): KOLOR Raw
    PostGISRaster -raster- (rws): PostGIS Raster driver
    SAGA -raster- (rw+v): SAGA GIS Binary Grid (.sdat)
    OZI -raster- (rov): OziExplorer Image File
$ gdalinfo --version
GDAL 2.0.0dev, released 2014/04/16
Feedback is welcome.
Best regards,
     Dmitry
