[gdal-dev] gdal2tiles from vrt with unexpected result
Andre Joost andre+joost at nurfuerspam.de
Wed Jun 18 12:25:48 PDT 2014
Am 17.06.2014 17:30, schrieb klo:
> VRT extend is approximately this:
> ulx, uly = (7436881, 4707326)
> lrx, lry = (7687838, 4511902)
Not sure if it helps you, but I just solved a similar issue here:
<http://gis.stackexchange.com/questions/88305/gdal2tiles-generates-small-picture-inside-256x256-tile>
I assume that gdal2tiles does not like -z and -p raster together.
This one has the same problem, with another solution:
<http://gis.stackexchange.com/questions/14761/gdal2tiles-problem>
HTH,
André Joost
