[gdal-dev] OT: openev(2) alternative?
Vincent Schut schut at sarvision.nl
Fri Jun 20 06:45:12 PDT 2014
On 06/20/2014 03:39 PM, Joaquim Luis wrote:
> If you are on Windows and 32 bits is not a (severe) limitation, I
> think Mirone (http://w3.ualg.pt/~jluis/mirone) satisfies those requisites
Ah, sorry, should have mentioned that: I'm on linux (64bit). 32 bit is a
limitation anyway, I regularly need to view very large images... Btw
building experimental stuff is no problem.
Vincent.
> Joaquim
>> Hi list,
>> this is a bit off topic, but I guess I'll have the biggest chance for
>> an answer on this ml...
>> Untill now, I always succeeded in (re)building openev2, but after
>> some recent system upgrades, it fails... I've used openev2 (and
>> openev before that) long as my preferred raster viewer. It is
>> blazingly fast, and has almost all functionality I want from a
>> viewer. Especially an easy mechanism to set which bands are r,g and
>> b, and to adjust the stretch, are important to me. And displaying
>> multiple rasters on top of each other, being able to easily switch
>> them on and off.
>> Now I'm afraid I need to look for an alternative. There once were
>> rumours of an openev3, but afaik that has never really materialized?
>> I've tried several others (tuiview, monteverdi(2), qgis, thuban,
>> otbiceviewer, ...) but none of them has the combination of being fast
>> and convenient.
>> I just need something that is good in displaying (browsing, zooming)
>> multi-band raster files. Anybody knows a viable alternative?
>> Thanks!
>> Vincent.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
