[gdal-dev] ArcGIS RestAPI JSON Polygons
Jeremy Palmer JPalmer at linz.govt.nz
Sun Jun 22 18:32:32 PDT 2014
I'm querying an ArcGIS service obtain polygon data, however the service seems to define Island multi-polygons objects as single polygons with multiple exterior rings. This creates invalid OGC geometries and is causing processing problems in my workflow.
He's the service and a validation test showing the polygon is not valid:
ogrinfo -dialect sqlite -sql "SELECT TA2013_V1_00_NAME, ST_IsValid(GEOMETRY) FROM OGRGeoJSON" http://maps.stats.govt.nz/wss/service/arcgis1/guest/Boundaries/2013_Geographies/MapServer/9/query?f=json&objectIds=36&returnGeometry=true&outSR=4167
GEOS warning: Hole lies outside shell at or near point 174.78189611685229 -41.077770200471164
Layer name: SELECT
Geometry: None
Feature Count: 1
Layer SRS WKT:
(unknown)
TA2013_V1_00_NAME: String (0.0)
ST_IsValid(GEOMETRY): Integer (0.0)
OGRFeature(SELECT):0
  TA2013_V1_00_NAME (String) = Porirua City
  ST_IsValid(GEOMETRY) (Integer) = 0
Is this a bug in the data from the service, or just the way the Esri defines geometry objects (and therefor an OGR bug)? I can't see a definition for multi-polygons in Esri API docs:
http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#//02r3000000n1000000
Cheers,
Jeremy Palmer
LINZ Data Service Manager
Landonline & Geospatial Services
E  jpalmer at linz.govt.nz | DDI +64 4 498 3537 | M +64 27 2747 862
Wellington Office, Level 7, Radio New Zealand House, 155 The Terrace
PO Box 5501, Wellington 6145, New Zealand | T 04 460 0110
W  www.linz.govt.nz<http://www.linz.govt.nz/> | www.landonline.govt.nz<http://www.landonline.govt.nz/> | data.linz.govt.nz<http://www.data.linz.govt.nz/>
[cid:image001.png at 01CF8EE6.FCAD45B0]
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140623/74224afa/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140623/74224afa/attachment-0001.png>
