[gdal-dev] ArcGIS RestAPI JSON Polygons
Jeremy Palmer JPalmer at linz.govt.nz
Tue Jun 24 14:43:28 PDT 2014
> My apology for confusion.
> I guess, your request is valid then you may want to open ticket.
No probs. Thanks I've raise a ticket here:
http://trac.osgeo.org/gdal/ticket/5538
Cheers
Jeremy
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
