[gdal-dev] ArcGIS RestAPI JSON Polygons
Jeremy Palmer JPalmer at linz.govt.nz
Thu Jun 26 14:21:58 PDT 2014
> Looking at the ogresrijsonreader.cpp code I can see I assumed that a
> esriPolygon was just a OGC Polygon, so with outer ring first and then inner
> rings. Fixing the code to support multi polygons should basically be a matter
> of calling OGRGeometryFactory::organizePolygons.
Thanks Even. Anyway to call this organize polygons via the python API as a short term fix?
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
